Were you with shannons?
How much did it cost, relative to what the agreed value was?
Some people have suggested this actually ends up 'making' money.
Who did the job?
Did you just do the engine, or the entire driveline, suspension, etc?
Mine is auto, there'd be a lot of wiring and random junk to do to. Most/all of which is undocumented and highly shit.
I was with just cars
Full comp insured for about $15k? Bought the car back for $3k
Who did the job? do you mean who assessed it? Some company down at Dandenong, next to Wheeltech, can't remember the name
I did just the engine, so sourced a 2nd hand neo and did that up. Mine was a manual
Who did the job?
haha so many questions...
just give to Scotty for another week...
im doing a complete suspension, drivetrain auto to manual conversion in my Cressida..
its a lot of work but couple of guys and a hoist could knock it over in a few days...
I can give him a hand to speed up the process if he wants....and look at the bright side, 1, you will profit from this, 2..now we dont have to fix all those dents in your car. so you saved more cash.....good thing i hadn't fixed it already hey .. ;)
damn, dat all....i thought you paid double that...
If my car was stock i wouldn't have bought it back
Cept I did all my new turbo mods just before, and still had the Volk Te 37 wheels. So thought worst case scenrio wouldn't lose that much money
Process is easy if you DONT need a VIV
If you do, forgetaboutit....you may get alot of headaches...
Hey its valid to ask!
Doing just an engine swap not always as easy as a more complicated (shit) swap/setup/changeover/random problem.
Re: Tony, meant who did the whole engine swap job itself. Though if you bought your car back for 3k, why did you get another engine for the car you were transplanting it into?
huh.
huh.
Oh I have a mate, who is an engine re-conditioner by trade, which is quite handy
New engine due to the old engine being melted when stolen/written off... :(
Old engine was melted / fried by 91 octane that the bloke that stole it put in at a servo, combined with burnouts etc...
Yup 40c day and 22 psi boost doesn't get along with 91 octane
I'm sure he had a blast though
I really should thank him for the insurance payout though
Ah right. Sorry, I thought the CAR was written off so you moved your working engine/driveline into a new chassis.
Kind of the opposite, you bought the wreck back.. and then got a new engine and put it into your old/original chassis.
This makes sense to me now.
Mine is insured for 27k, which is the same cost as that GTR.
There's not many things a neo with an auto transmission, suspension setup for a 4DR, diff and driveshaft for a 4 door, exhaust for a 4 door will really fit into easily other than well, a 4 door.
Or maybe a S15.. they had the same auto originally... :ph34r:
Go buy the GTR
Then tell us what it's like once you are inside the inner sanctum of the GTR/Melbourne GTR/R33 GTR owners club!
I reckon he should be telling us how long he has left to live after he contracts aids from all the gay sex
Hrmm my car was listed as a repairable write off though insurance though
Just keep the neo engine, and go to a 2dr/manual of some sort
:woot: I doubt they will write that off unless its severly bent....
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
