Will need a VIV, once it's classed as a stat right off needs a VIV when it gets repaired, that's of course it can be, some repairs won't be allowed to be fixed
Nice looking car that one, would be a sick setup
Kinda looks like it with diff wheels, or has yours still got the same wheels?
Repairable write off doesn't always need a VIV brah
I'm into building awesome cars then swapping them for wrecks :/
Haha nice
80s Alfetta - sold to wrecker
80s mazda 626 - sold to someone to turn into a race car
S12 Silvia - sold to some p plater
Ford Laser and Mazda 323 - given to someone that races a laser.
Kawasaki zxr250 - sold on ebay
They're just the ones that never had rego
fahhh,
80s s class merc- sold to some old dude
90s import hilux- blew up- junked it
r32 gts4 sedan- sold it, new owner modded it and sold it to another dude that wrote it off
vt spack chaser- sold to mate, written off
R33 GTS- refunded, written off 2 days later
R34 sedan- sold to adelaide, now milenium jade, GTR front and 300+rwkw
current sedan- shitbox
fahhh,
Got pics of your ex-sedan in millenium jade?
Haha nice
actually the skyline was the first car I have ever sold/swapped off....everything else before that I just plain destroyed or abandoned... only 2 others made it out alive and they were on lease/finance
Haha nice
The dailies:
Mitsubishi Starion (bought with engine issues) - Sold to enthusiast
MZ21 Soarer - Sold to guy, blew engine on GOR not changing above 2nd
R33 Skyline Sedan - Sold to drifter, now with Battery
S13 Silvia - Sold to some guy, changed the turbo and blew the engine
626 wagon - Given away for parts
3.0RB Liberty - Current
geezus Justin, you get around.
'90 N13 pulsar - bought off dad. dad paid for new head gasket then sold it.
'99 N15 pulsar - sold to some dude who thought his falcon F6 would be worth money some day and wanted a cheap daily (lol)
'98 N15 pulsar - went through 2-3 motors with previous owner, 1 motor with me. and hopefully stays that way.
Future?
2007-10 Volvo C30 - badass FWD torque monster
N13 pulsar - N/A CA18 with bolt-ons, stripped interior.
kit car?
1987 VL Calais - sold to some random
1997 R33 Skyrine GTST - written off hail damage (its now in QLD as a track car)
2004 BA wagon - SICK JET BEAST, bucket of bozz, daily driver (current)
2004 mitsubishi evo 8 - current weekender
JD camira - written off
Wrecker camira bought after first one written off - became paddok basher
e30 318 - sold to a normal person as a daily
e23 735 - sold for scrap
VK wagon - written off
R33 - sold to fucktarded P plater that wrote it off after a few hours
Evo 7 - pending sale
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
