you word things weirdly. though i knew what you meant. just thought maybe you had done most of an epic marathon of some sort.
I've been doing an epic marathon for the past week and a bit lol
y'all whinging about someonewho has dialogue and a name nobody remembers being killed off.
back in OZ, average of 1 character death per episode. that shit ran for 6 seasons. OZ was doing it before it was cool.
OZ was the bidness
And sharpened finger nails, so boss
that scene was BOSS
Jumping on car list from few pages back.
89 R31 wagon, full of rust, parted out
88 R31 wagon, swapped for coupe roller
86 HR31 GTS coupe(base turbo not natro) bought as roller, sat, collected some bits ended up on eBay
91 Hyundai excel, rolled
88 Honda prelude, bought with front end damage, repaired, filled with coolant, leaking, figured water pump gave to workshop to fix/rwc, turned out block was cracked in accident, left it there.
96 R33 taxi, drove it, loved it, shat auto, took off road, threw money at, sat, got over it, parted out
93 R33 coupe, bought t boned, parts car, parted out
86 Toyota Corolla, borrowed off mum, shat engine, replaced with engine from other, shat gearbox long time later, mum cbfd so went to scrap
85 Toyota Corolla bought for $100, pulled engine, sold for $100
81 Nissan Bluebird, bought from original owner, low ks, dailied, shat head, replaced, cam gear dowel somehow came out of new head on test drive, turned both heads into 1 good one. Went to ballarat, bottom end died on way, towed, probably still at depot
95 Nissan Maxima, bought off sister to replace bluebird, now going to my dad
93 Subaru Liberty RS Turbo, new daily fun car
and you're still on your P's, yeah?
chasing a quote for a custom-made sump. any recommendations?
is scotty busy? car is off the road so will probably only be able to give stock sump and photos for an idea.
I have never made a sump before, but if you have pics I could probably copy some other design...
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
