ah cos its absolute pressure
ie at idle or sea level pressure is 14psi or 100kpa already
so pressure is 262kpa, minus 100kpa
gives run time boost at 4800rpm
162kpa, gives 23PSI, geez
i wonder if thats right, thats from the vipec map sensor
the eboost one doesnt show that high
hmmmm
yeah not sure on the "statistics" page
some of them make sense, some are really way off
ie # of times started and run time in minutes seems reasonable
but then you look at peak ECU temp, 13000deg celcius???
max intake temp 12,000 deg
max volage 184
probably worth clearing them
but then kinda dont wanna clear the # of times started and minutes
Why, they are unrealistic too...
Started 36,000 times...that's 10 times a day everyday for 10 years and average 1 minute per run. Unless granny drove it to regularly and compulsively check for mail at the end of her driveway, or it had some serious starting issues, I call bullshit.
yeah the max temps and max #s are really really wrong
but the run time in mins and started sound somewhat believeable
i plan on keeping the car so ill probably erase the stats back to zero
cos it would be kinda handy to have some of the top scores over time
but currently theyre all whacko
cos it tracks # of times you hit limiter, #s injectors max, total knock etc
but currently they're all mega high
I felt an accomplishment driving into Bayswater @ Import monster and leaving without a defect today
fark that's lucky as! i heard pettit was hosting a defect shop near barry st bayswater today :s
nasty
whats the defect for
height below 100mm, pod filter unsecured pod filter and exhaust doesn't comply with noise standards. also have to provide a rwc. fun times :/
Luck of the draw mate, eastern burbs just increases the odds
true that :( booze bus turned into defect station.
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
