ah cos its absolute pressure
ie at idle or sea level pressure is 14psi or 100kpa already
so pressure is 262kpa, minus 100kpa
gives run time boost at 4800rpm
162kpa, gives 23PSI, geez
i wonder if thats right, thats from the vipec map sensor
the eboost one doesnt show that high
hmmmm
yeah not sure on the "statistics" page
some of them make sense, some are really way off
ie # of times started and run time in minutes seems reasonable
but then you look at peak ECU temp, 13000deg celcius???
max intake temp 12,000 deg
max volage 184
probably worth clearing them
but then kinda dont wanna clear the # of times started and minutes
Why, they are unrealistic too...
Started 36,000 times...that's 10 times a day everyday for 10 years and average 1 minute per run. Unless granny drove it to regularly and compulsively check for mail at the end of her driveway, or it had some serious starting issues, I call bullshit.
yeah the max temps and max #s are really really wrong
but the run time in mins and started sound somewhat believeable
i plan on keeping the car so ill probably erase the stats back to zero
cos it would be kinda handy to have some of the top scores over time
but currently theyre all whacko
cos it tracks # of times you hit limiter, #s injectors max, total knock etc
but currently they're all mega high
I felt an accomplishment driving into Bayswater @ Import monster and leaving without a defect today
fark that's lucky as! i heard pettit was hosting a defect shop near barry st bayswater today :s
nasty
whats the defect for
height below 100mm, pod filter unsecured pod filter and exhaust doesn't comply with noise standards. also have to provide a rwc. fun times :/
Luck of the draw mate, eastern burbs just increases the odds
true that :( booze bus turned into defect station.
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
