Depends on lines; with baggage, the earliest, I call 8:45.
If you're trying to skimp on airport parking then park at Maccas and wait for phone call...or chance your 20 minutes in the wait and collect zone on the way to terminal 4.
Or do what other tight asses do and pull over on the Tulla pretending to be broken down lol
The maccas outside the airport can be a pain for parking since all the chauffeurs park there... Try getting off the exit before the airport, there's a much bigger maccas just at the exit. Think that exit is called mck something.
thats a kinda busy time at airport, on a plus note it means more ppl working. lucky it just b4 a 380 but if her flight delayed it will push out quickly.
I normally go with 30 min.
that said I have been in a taxi in under 10 min from landing once!
make sure you track the plane to know the actual landing time and then work with 15-20 min from that.
RS5 y u no drag me. You didn't buy the sports model, you bought the racing model...why do this if you're gonna take off like a Hyundai Excel. Did the smell of burning sugarcane scare you?
Answer me!
Answer me!
ill drag you big fella.
just gimme a while to sort some tyres.,....
speaking of. anyone know anywhere around dandy area that can open the centre bore on a set of wheels?!
Answer me!
RS4 was no racing model when I drove it, my guess is the RS5 isn't much better.
even worse this morning
but when you command a 350kw battle ship nothing is a racing model :woot:
Perhaps. I just expected more.
I think it needed twin turbo and ethanol, but there just wasn't room, and it was a hatch so no boot. :P
only rs model ive ever driven was an old rs6 wagon from (i think) early 2000's. was a mint car on das autobarn.
Take the "Freight" exit, which is currently used for the Long Term Parking, on your left there will be a waiting area designed specifically for people like you who just want to hang out and wait for planes to land so you're not doing laps constantly or clogging up maccas.
http://melbourneairport.com.au/news-events/listing/overview/ring-ride-waiting-zone-.html
Mickelham Rd?
This. I sit in the car park till i know the person has collected baggage, then sit in pick-up zone waiting for them. If you get kicked out, do a lap round the block and start again.
BRING IT OOOOOOOOON
Meh, I just don't drive to the airport since it costs me $80 in fuel for the trip.
Came back from Sydney on Monday... Long Term Car park from Saturday 7am until Monday 11am cost me $70 (3 days).
I seem to remember leaving the car there for a full week once, and I think it was about $90... Blergh.
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
