RS4 was no racing model when I drove it, my guess is the RS5 isn't much better.
30 more kw and another 100kg
Prolly similar
Still pulls a 4.5 second 0-100, would have been a good contest given my propensity to face diagonally until second gear!
RS5 y u no drag me. You didn't buy the sports model, you bought the racing model...why do this if you're gonna take off like a Hyundai Excel. Did the smell of burning sugarcane scare you?
Answer me!
because you touch yourself at night
Spend $20k to get both.
Bahahaha! Nice thinking Grant! But unfortunately not to be.
Which setup will give you more gains?
Both will give similar results, with the supercharger giving between 350-400rwkw but with bucketloads of torque on tap from basically anywhere in rev range.
Single turbo (either a Garrett GT4088 or equivilant Turbonetics turbo) will be pushing around that ballpark too, but more likely to touch and/or topple the 400rwkw mark. Being on a 6L, can't imagine a lot of lag but won't have the level or response the charger has.
So similar power but with 2 different characteristics...
You after low down response or top end?
Spend half on each and you get both for 10 large?
:P
Going by that logic, I'll have a water-to-air intercooler installed, as well as the front mount air-to-air intercooler installed with the exhaust manfiolds, but no turbo and no sueprcharger. LOL!
  • Like 1
Yeah basically!
Umm... both? hahaha To be honest, I'm not even 100% sure what I want, all I know is I have boost withdrawl symptons ever since selling my 33 and in search of my next boost hit :(
Personally I'd be going for the SC option, for a street car the low down goodness is going to be much more beneficial. Just change gears earlier ;) You'll still be going 200kmph be the time you run out of gears at low revs :P
Do that, and film people (including finest constabulary) reactions when the bonnet is open.
Yeah basically!
  • Like 1
Hmmm true true. I would probably be swinging towards charging cos I've had a turbo 6 before, and the car is currently cammed so can say I've had a cammed V8, so I guess the only thing I haven't tried is a supercahrged 8. Hmmm....
bring to scotty and do it for less lol.
Hahaha you keep saying that! But how much can Scotty do it for though? A GT4088 is about $2.3k on its own, plus a decent cooler core probably about $600, external wastegate about $800, BOZ about $400. Add in lines, fittings, piping, tuning and labour and I reckon I'll be close to nuding the $10k mark anyway :(
That'd be asking for an ass reaming LOL
Hahahahahhahah! You better believe it! ;)
  • Like 1
:laugh:
Up to you I guess, I mean, it's a 6lt and as you know, it ain't short of low down torque.
Put the turbo in for some nice top end fun.
Well once it kicks in from the low down torque, it will still power all the way through.
You'd probably just start spinning the rear tyres a hell of a lot more :)
:laugh:
Hahaha, yeah that's the only thing that is making me think supercharging, cos even though I LOVE the violent-ness of a car coming hard on boost with a turbo, the crappy commo would struggle to put that power to the ground I rec kon, even though it weighs almost 2 tons
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
