Just double checked to see Orlando wasn't in the list I posted.... I don't think I could have ever lived that one down
yay, my kids names are not on the list :)
Too hipster to appear on the hipster list...
Sweet as mate, bring the Cressy down
:thumbsup:
i wanted to call my second daughter Chilli for a while....good thing i was talked out of it, turns out Craig Lowndes kid is named Chilli...
I dont think I could of lived that one down...lol...its actually worse than calling your kid Brock
Going into it solo /foreveralone style also.
well theres ya problem.
but yeah +1 to too big of a financial commitment for me to bother.
interest, rates, stupid long mortgage + possible body corporate... fun times.
rather just use money to get by, have fun, then go live in a commune fearing barcodes and communists and await the inevitable rapture/2nd coming of son of rajab. etc etc.
then use super to buy a houseboat or something. whatever.
Pretty much... much harder solo unless you're on dat dere 6 figure + (inb4dezz) bachelor pad
Then my brain thinks of all the bad stuff that could happen.. get mrs, nek minit divorce and take half.. or nek minit made redundant at work, so could always rent but then money wasting away sorta. So far off the plan seems to be winner.
Edited by UNR33L
if you ain't no punk, holla we want prenup!
There's a woman at work who keeps saying she's from Mornington, but in reality she's more of a Frankstonite... Her kids are Crystale and Roxy
I'm honestly not sure how they didn't become strippers by word association
this is true.
reading through some drafts for a pre-nup recently... whats the point of an investment if someone can take it all off you? i'd rather just get some paperwork to keep it protected.
honestly I think any-one who is doing a pre-nup is expecting it to fail and prob shouldn't be married in the first place.
that said live with some-one for 6 months and they can take half anyhow. so too late for that prenup
When i learned that (maybe 12 months ago) i jumped on the wagon.
And also that if living with someone and theyre applying for welfare, the government expects you to support them. Which explains why its usually more than one person per household on welfare.
It doesnt guarantee anything, but i feel much better knowing there is a document stating that someone is a border and not a defacto or that certain shares/cars/investments are solely owned by someone or was owned previously to entering a relationship.
this is true.
I inquired about pre nups when I bought my place but was then advised that there is still ways around it.
Correcto, you can structure things and put agreements in place
But there is no 100% guarantee when it goes to Family Court
  • Like 1
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
    • G'day ... first up, I very much doubt that's a resistor network (as used also for this job), but the part# looks right. The description of 'power module assembly' looks to be nissanese for 'PWM driven, ground switched, DC motor speed controller'.... the circuit in the schematic kinda infers that's the case... ...with the transistor symbol appearing in the unit described here as 'Fan Control Amp(lifier)'....being driven by pin20 on the HVAC unit,  and a feedback signal on pin19 from the motor negative terminal for some reason (might be motor fault detection, maybe they detect commutator switching to determine motor revs as well, I dunno)... but if they are  counting commutator spikes, a bad segment (or really worn brushes) will throw a spanner in the works... The motor itself will as said be brushed DC with segmented commutator, rated at 12VDC nominally ~ now-a-days I just unplug them, determine the positive wire, and hook them up to a variable power supply and find out how much current they draw, if they work etc etc ...you can also check for bad segments...ie; set the power supply up to feed 1volt @ 2amp max, then watch the wattage count as you slowly rotate the fan blower motor through a complete revolution ; any bad/dead segments will be clearly evident...some folks would just say determine the positive wire, and feed it battery voltage, and if fan spin, you've got a win...<grin>... well, at least that infers it should do something when plugged back in, and the HVAC unit commands it to run... and if it doesn't, you suspect the module, but you should check the PWM signal on pin20 is actually present, and if it is, blame the module ...
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
