if you're baller enough, AD08s.
track yes, any day yes, i'm throwing out my 20km old 123's for them (thanks for that SIMON)
but for street meh
was going to keep and total them at a deca but seing that not happening, no point
I have been summoned.
They're fine for street, but as martin has said, they can run out pretty quick on the track when they get heated up too much.
For street they're great grip for the price. I just picked up a new set for $220 ea, where are you getting them for that price? Cheap Cheap... Make sure you check the age!
  • Like 1
123S? They're not semis, they should be just fine for the green monster considering its so light weight.
Though, you could go for some small AD08's if they make them that small... miniwog has been running them on his 86 for a stupid number of track days and street km's, gotta be due to the lighter weight of the car.
Actually...
http://www.achillesradial.com/en/tires/racing/achilles-123s-3
Are they even available in anything under a 17?
Normal 123 perhaps?
http://www.achillesradial.com/en/tires/racing/achilles-123-2
i need 14's and there isnt much in the way of fast street tyres. so im looking at tarmac rally and semi slick options.
just wondered how long they last....
so far only thing i have is silverstone tarmac rally in a hard.
and federal 595 in street trim.
i need 185 55 14. or wider equivalent.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
