#@r34abz mate, as long as you don't have an inter-cooler with that pod, it's fine. As Alvin said, one intake mod is ok and if you've got everything stock you'll pass. EPA's are the reason I don't want to get an aftermarket exhaust.
  • Like 1
Check out this Mitsubishi Lancer.
http://www.carsales.com.au/private/details/Mitsubishi-Lancer-2001/SSE-AD-2839584
Nick is this yours?
Nope, mine sold on fleabay not long ago for $12k, un-regod, no rwc, recent engine swap, shit condition car overall and still had the jdm-007 plates
bit steep, are they forged? I got brand new TE37's for a little bit more than that...
I have no idea what my stud pattern is, what widths/offsets I'd need etc.. haven't looked into anything yet
pcd is 5x120 so same as bmw
however not sure on offset, would need to pull a front and rear to check if stamped on inside, if not need to measure and calculate
measure the exact width of th rim, from outer edge to outer edge (may have to lay it down and go with a tape from a flat surface from bottom to top as it's got tyres)
then measure from wheel hub to the lip on the rear
take the first measurement (lip to lip) and divide into 2
then take second measurement (hub to lip) and minus the first measurement from that
Meisters are rad. Sort it out Leroy Jenkins
LEROYYYY JENNNNKIIIIINNNNNNSSSSSSSSSSSSSSSSSSSSSSSS
Not forged, good luck finding good forged rims in these type of sizes for anywhere near this sort of money though ;)
Sure, if you ran pulsar sizes you could buy TE37s cheap.
:D
Green shell killshot just before the finish line is the finest play in the Mario kart book
there is a decidedly real satisfaction from sniping with green shells
but i was foreveralone playing with computer
Way too much effort. I'm sure it's on the internet..
Pretty sure it's just 2010+ models with power to weight of < 130 kW/t
Anything older will continue to be banned as per current rules / power to weight
I think you may be able to get a Golf R now. Saw some talk of this. Definitely the GTi I think?
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
