Yeah I'll be there :) My car is back together thanks to Mike and Rob coming around and motivating me to direct them to put it back together ;)
On the plus side, now have 27mm Front and 24mm Rear Whiteline Swaybars installed, feels so much better already after just a quick spin around the block.
Did you purchase the Power Intake adpator too? I don't think those come with one.
As listed here:
http://www.apexi-usa.com/store/induction/power-intake/universal-adapter-flanges.html
Oh and next time, save yourself the money and just buy a 3A racing pod off ebay for 30 bucks. They filter well and are cheap (as a piece of perforated cloth and some stamped metal should be).
Nah haven't purchased the adapter yet, I heard the A22 model was a directly bolt on that's why.
I don't think it will work with an adapter, I think with this kind of POD it needs to bolt directly on.
How is one supposed to skate epping plaza with such a device?
That is actually a very good question.
The answer will be revealed in say 10 years time when them habibs can afford one of these in cash.
Love them or hate them, the VF commys are a respectable bit of kit. Electronic park brake is fkin cool.
13.8L/100km average on LPG, that's close to diesel economy when you convert to dollars, isn't it?
its definatly close..
So, Orlando has an upper respiratory infection, which then lead to 3 other infections.
He's been sick as... Just lying in our bed crying or sleeping for 3 days.
last night we took him back to the hospital as he hadn't eaten for 36 hours and wasn't taking fluids...
He looks terrible at this stage.
Literally AS the doctor comes into our room, he jumps up, trots over to Merowyn's bag, rips out a croissant and starts eating it, then has a drink and starts trying to use the hospital as a jungle gym.
Little bastard...
So I purchased one of these which has an 85mm ID:
http://www.apexi-usa.com/store/catalogsearch/result/?q=500-a021
Not realising I need the 500-A022 model which has a 75mm ID. Anyone know how I can make it fit to the RB25DET? Would an adaptor or the like work?
The square gasket doesn't bolt straight onto your AFM?
You would need a reducer if it's too big. I'd just suck it up and resell the 21 if it won't fit. I sold a used 22 for $30 second hand lol
Hope he gets better, is he continuing to eat and drink? or was it a one off to piss you off in front of the doctor?
Sounds like taking your car to a mechanic to diagnose an intermittent problem :P
oh he'll get better.
he's much the same today. It's heartbreaking, but then I look at people who's kids have real problems like leukemia etc and it puts it all back into perspective.
It's just a part of parenting
thanks for the thought though <3
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
