Also want to be taken for a spin :D
On another note, after going from shagged 275 NT05s to 245 Dunlops I've gone from traction in 2nd on good roads to 'lols' but I don't feel like I'm going to spin out to a tree in the wet which is nice.
Inb4 flogged out Falcon up for sale at ridiculous price.
:P
lulz.
she needs some work yet...... i need lower rear springs, front and rear sway bars, scotty to make me all manner of bracings, and some freaking tyres.
maybe lsd...
Acid will not help you drive a car
If you wanted a 4wd micra, probably a better bet to start off with something like the Familia GT-R and then mod that... they're little rockets when set up right. 154kW for something that weighs about 1000kg, not too shabby as a starting point.
but they break and break hard. gearboxes and diffs are weak as. few parts drifting around from old projects but people usually stick to them for rally and keep them tame.
generally not too common because ugly + heavy. and those that are still around have been flogged by GTR wannabes. still fetch a decent price since purists will start to restore them. they had heaps of nismo optionals etc. (for a small JDM car anyway)
Up late on a Friday night with nothing to do? Ever been scammed by a guy named Jayson from the Blackburn/Burwood area? Haven't heard all about the massive scammer who has been operating here for years?
Why don't you read this thread from page two onwards, where you can -
- See forum member Jayson F, or gtr2nv, known by a variety of other usernames including jet31 (banned on this very forum) not defend himself ONCE against numerous posts linking him to all his other scamming usernames for a period of 7 years!
- Hear from other users who he has stolen from, and then sold the stolen goods on the very same forum!
- Read about how the post office seems to lose some items for which he can't produce receipts!
- Learn about how when some items arrive, they're thrashed or internally cracked!
http://www.skylinesaustralia.com/forums/topic/441101-fs-brand-new-kinugawa-kando-t67-billet/page-2
On the subject of converting to AWD
Should I buy a gtr with my write off money or is the ol gtt/gtst considered on par around the track nowadays when set up well?
Buy back wreck, buy one of the myriad of sub 1k rolling shells or sub 5k gtst's and swap everything in. Spend the rest of insurance cash on more fruit.
Really actually buy Grants 33, huge KSports, Teins, RA3-DT's, tidy interior. Bodywork is not so tidy so it'll be less upsetting when you bend it again :P
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
