Finally got my car back today :) Although I don't think the wheel alignment was done properly, steering feels a lot heavier and for some reason the car feels slower :\
maybe you got excited for boost but was let down by stock.
time for some hypergear + scotty hi-flow.
Always took simon for a receiver, not a giver.
This I can confirm!
Have a look down near your Alternator, in front of it (sort of below more so), theres a power steering line which should have a sensor tee'd into it. See if someones undone that plug as it's fairly common cause of the steering being heavy.
This I can confirm!
Thanks, I'll have a look tomorrow. I had a quick look at my car tonight (through the heavy rain) and I think they've done the alignment completely wrong though, seems the camber (and possibly toe) are out, which explains why it feels slower as well.
Did you get your Alignment printout? Get it fixed if they've screwed it up badly (it's gotta be hellishly out if its actually causing so much drag you can feel it being slower)... and it'd be munching through tyre already
Dan Murphys have a limited edition royal salute for $120 a bottle delivery only
bought one for myself and 2 for the old man and orders over $300 are free delivery
https://www.danmurphys.com.au/product/DM_779879/royal-salute-world-polo-21-year-old-scotch-whisky-700ml
Nope, the panel beaters took it to another shop to get the alignment done so I don't have any documentation. I knew I should have sent them an e-mail with the wheel alignment specs, most shops are horrible at getting the right specifications for imports. I remember on my last car when I needed a wheel alignment and I told them I have the specs for it, they just said "Don't worry, we'll work it out" and I foolishly believed them. Got the car back and it was terribly out of alignment, they are just too lazy to look it up.
I'll be calling up tomorrow to get them to fix it, because it definitely doesn't handle as well before the alignment.
DMWEL0714 should give you free delivery too, alternatively
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
