Was pretty good
I dig the decor too
Honestly knew nothing of him running a new one until he came up and said hi
What's the place called?
And it does
Thanks to you both
You're welcome :)
Was considering it too... but not sure if worth it; but looks cool to start a stash/collection of stuff that isn't just for going out once and smashing it all lels
You're welcome :)
Il Tava?
Yeah I have a small collection of scotches/spirits and wines; thought I would add something that seemed like good value. Even standard 21 is $150 odd.
Il Tava?
yeah also can find that 21 for less than $200 anyway
Another to add to my growing collection also
Mate is coming back from Singapore next week.. Hoping he will deliver the cheap booze goods.
Thinkin some more Henny and some Goose
Martell / belvedere > henney / goose
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
