Yeah I know. Worst aprt is, the missus brought a set of matte black 4x100 rims in a tough offset and look mint (look almost like TE37s) but the offset was too aggressive for her as she didn't want camber of anything like that, so looking to sell them or trade them :(
well what the deuce!
what size are they man??!? give me some details :woot:
They're 16x7 and still have decent tread on the tyres. Not sure on brand but they look mint, which is why I'm spewing she doesn't want to keep them. I'll send you some pics to your phone now mate :)
man, they are way to big brother :( 15's i could make work, but 16's i have no chance.....
leeroy?!?!? want some rims for the poosar?!
No stress mate, you able to psot up the pics? I can't post them up cos I don't my phone cable with me :(
Is Artz new jerb near you? He has a ute... :P
Otherwise, I can't fit too many pallets in the stagea, and not even a chair in the back of the evo. lol.
No idea... Tulip St, Cheltenham.
They're going to the tip first thing on Friday morning in a skip, so you'd need to pick them up before then.
5 full sized pine pallets + 1 Beefy CHEP quality pallet + 1 x 44 gallon drum pallet (like birds posted on the back of the truck)
Anyone selling 4-stud of PCD 4x100 wheels? The missus's Civic could do with some new shoes.
What about these?
http://www.rotawheels.com.au/wheels/rota-slipstream
Or are you looking at something cheaper and second hand?
whos got the driveshaft hookups round here fellas?
i need some driveshafts shortened, and a differnent cv putting on the hub side.....
Knox Drive Shaft Services. He's not the cheapest man in the world, but he's definitely one of the best!
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
