Instead, I'll leave you with this:
Wouldn't have mind doing that except I was far from all by myself.
hope the interview and assessment centre went well bro! good luck with the results.
thanks hipsterman!
Really hope I get to the next round, will have to shout wasteland some springsrolls if i get the job lol
um go to the lounge and relax with free food/drink?
ummm..... I don't even get free wifi let along food/drink :closedeyes:
thanks hipsterman!
in for springrolls meet! or pho if it's still cold :P
Tiger airways, cheap and nasty for us fellow unemployed eng graduates :thumbsup:
haha for domestic could probably get jetstar to price beat :P
ok travel rant for the day.
looking at a hotel in Fiji for a short break.
4 nights for 2 people.
they have 2 packages.
both same room
1 is room only
1 is room plus breakfast.
$620AU difference.
how the hell can breakfast be $75 per person per day!
How are ya'll getting 27gb/month?
I'm on 1GB/month and average about 1.5GB/month... there's a bug in my plan where excess usage gets absorbed into my cap... so I need to his 3+GB before I actually start getting charged
Every time they call me, they're unable to offer me more than 1gb of data without increasing my monthly spend of $49 to something stupid like $60+, even with offers to recontract for 24 months if I had more data applied.
Want to stay with Telstra as well...
'Unlimited' telstra 4g here hehe!
Well we have ~350 work iphones with 5GB pooled data we never get close to that so yeah.
Think the most I've got it to was like 60GB lol boss is like wtf
Edited by UNR33L
Unles its a buffet and yourself and your travel partner eat like buffalo I'm going with rip off.
When I was in fiji we got our meals included at our resort, if we didn't it was something stupid like 20 for breakfast, 20 for lunch and 30 for dinner... plus drinks obviously. was too far from anywhere else, and the food quality was good, so was happy to pay for the meal package with the room.
No buffalo eating required, the 3-4 courses per meal were more than enough :P
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
