they are not a good pad for street.... also they chew rotors too much for street
better to go something like EBC red if want street pads
Yup qfm spokesperson validated why my rotors disappeared in 15,000km of street driving with a1rm.
They chew a lot when cold.
He said the qfm hpx are the best street pad from their range.
Been using them ever since and no issues.
I killed a set of A1RM's at calder in one day...never again.
(and remember I'm traveling slower than most here and with a lighter car.)
were great at deca tho.
I'm trying a few new ones now the ones I were using no longer in AU.
so I want to drain the fuel on the 200 as it will have been sitting for 6+ months b4 next track day.
I'm thinking easiest way is to pull the outlet hose off the fuel filter, put some fuel line on that into a jerry can and just turn on the ignition.
need to change fuel filter as well so seems like a good time for it.
any-one have a better way.
Really good article... Note for once it concentrated on actual issues and solutions instead of "Speed kills", "More Cameras are needed to save lives!", "HOON!"
I think I've got a night there too, will post results. All I've heard is it's expensive but very clean
if going to salzberg
and you drink beer
hit this place up
http://www.beerdrinkersguide.com/BDGWebsite/Gardens/AugustinerSalzburg.htm
full of locals , and they have a little "street" of food places where you can buy want what your want from each, everything from salad to most of an animal
plus cheap
the cheese Kransky's we had were spectacular
I just use the return line off the rail and idle till done.
done it heaps of times
The CP5070D54 sized pads fit. Most manufactures make these.
You can get them in DS2500/3000, HC800/Club Racer, Blue (DP5006)/Orange (DP9006) Stuff.
I really liked the project-mu, but it was costing too much. So used the Blue, then went to the Orange when I stopped driving it on the road.
Yep, I was told the "pads for k-sport/d2" should fit but you may need to modify/grind the pad a bit to fit, which meant it didn't fit. Either that or buy the actual pads from the JJ site.
So will these fit without modifications?
Also Simon, the green pads that come with them are baaaaad. I mean they're good for street, and by 'good for street' I actually mean I had a fair amount of brake fade in the hills with a 356mm set vs the standard brakes which had none.
hence the research into pads
:/ We'll see how it goes I guess. due to the fact I won't be able to just pop down to repco/sca to pick up pads anymore, I'll always have a spare set on hand... so will have time to experiment and see what fits and what doesn't...
Won't be tracking it for a bit, getting these brakes killed my car budget for a while... But when I do I'll be running great pads on the track, and swapping them out for street pads when I get home and take off my track tyres.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
