What do 33gtst fuel tanks normally go for? I've got one on the floor of my garage taking up space...
They worth a pineapple on drift sales or not?
Its got maybe 5L of 18month old 98 in it, so that'd raise its value in the eyes of some of the drift kids
Not sure its worth someone knowing my address and location of car :P
no ethanol, no deal.
Bought some floodlights inside the garage, never have night lighting issues again...
Good size, nice and solid waterproof metal casings...
Earth wire, CE Logo... goood goood...
Fúck you Chinese Safety, super kwality number 1!!!
There are screws in the vicinity which they could be attached to in order to make it safe against electrocution, considering the complexity of the product... it would take an additional 3 seconds to make (on a 5+ minute assembly time). Increasing the quality and safety of the product substantially... which could raise the number of sales compared to other dodgy competitors.
My company does our equipment production in a Shenzhen factory now, we thought it would be a set it up, train them then forget it process... Nope, we've now got one of our staff permanently in china to oversee the operation because standards drop within a week of him leaving the factory floor.
I dun get it
Why would they increase the safety, you already bought the product and your negative review won't stop others either
People buy this stuff cause bargain bin China
It's like the split dump pipes on eBay...absolute f**king garbage and will actually f**k your turbo up, bad reviews everywhere, but because $99 and shiny people still buy
  • Like 1
Yeah ebay, from an Australian seller... Will make them electrically safe and then test them for heat output over extended periods of time before installing them...
I got 5 x 30W ones... If they were halogen ones I'd need to put on sunscreen, these are LED so I'll just need sunglasses every time I go into the garage.
ouch at the earth thing.
i recently bought one of these:http://www.ebay.com.au/itm/310876695793?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
aldi were selling them too. pretty handy.
that looks quite good, handy for track days too, happy with it?
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
