43 Megapixels? uwotm8? They threw that number into the keynote to get some wow-factor... however they were referring to how large a panorama image can be now... It's actually 8mp, but with a really good sensor and lenses.
Adam is on ethanol. No f**ks given for EPa so long as its not loud?!
Either way a stock exhaust for the day will be fine man.
Illegal to modify ecu or fuel setup in vic. So I cant see many cars where e85 could be legal in 90's cars
fixed for accuracy.
He actually does ask me that every morning and it does piss me off... As well as 'get up to much last night'?
I couldn't look any less interested if I tried, yet still he asks me the same shit every day
Hi Michael how are you?
nistune is undetectable, and your fuel pump went so you replaced it, and you run ethanol cos its cheaper.
shit switch on man.
but yes, a nistune setup is the least detectable around. also need to remember to paint the injectors stock colour
also, birds would have so many issues with your for sale ad dude. not once did you quote a reachable power figure, but twice!
also, glws.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
