Offfsets aside, clearance to the actual circular wall of the wheel was the issue with my 17's... Wouldn't have been a problem at all with 330mm rotors and the 8 pots... but I ended up getting sent 356mm and a different mounting bracket to suit.
The 17" AVS Model 6's DID fit onto the hub, and it DID spin (but it was grinding on the top and bottom of the calliper... and would definately be bad times especially once the rim flexed a bit on a bump or the calliper expanded)
Hey MohMoh, want to buy some sick JDM 17" rims from me?
Anyone ever have a look at an indicator/lights stalk on a 34? Is it shared with anything?
Looks to have 3 plugs. One is missing. Indicators don't work. Except there's nothing on the loom that's unplugged.
Only thing recently removed was a Turbo timer. The turbo timer had exactly 0 plugs involved with it at all.
What in the actual f**k.
Have a look if the warning button is stuck. Happened to me a few months ago and I was wondering why the indicators stopped working. Turns out the warning button was so ever slightly pressed down :)
..... warning button?
I should state that the hazards work, the fuse is not blown, and there's actually very much a missing plug connected to the stalk. There's 2 of three things connected there and I'm pretty certain if I had a working R34 I'd pull the plug out and see if indicators continued to work... because everything else on the stalk works except indicators ;)
It could be actually, that's what I'm not entirely sure of. I've found it hard to find out what the problem actually is, or an exact wiring diagram of how indicators are wired in.. it not being a fog light equipped car would explain why there's a missing plug and a loom which has no obvious disconnected plug attached to it...
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
