Anyone got clutch hookups? Shopping around for a replacement atm. The rougher the better
I know everyone says go to NPC or Nismo but I put an Exedy heavy duty in my car 5 years ago from here (http://www.icesrepairservices.com.au/products.php) and I've never looked back.
For $400 it has held 325kw at 20+ track and drag days.
I dunno if the price is still the same though.
He's got 99 problems but a clutch ain't one
I was going to like this post until I thought about it, because a clutch is, if anything, his one problem right now.
Current HHDBC has been in for a bit under 4 years, not too pleased it's slipping now. Will probably go NPC. What was the damage for yours Toby and Adam?
Mine was about $500-550 from memory; 10" carbotic - biggest clutch that will fit in our bellhousing. I believe they are derived from 350Z clutches. Rated to 300rwkw+
Can get any contact plate you like but I went with an organic cause they said it would stand up to my drag launches...they've been right so far. Also my thrust bearing is being pressed up against the plate (creates a whirring feel through the pedal) and I haven't been assed to adjust/fix it for 3 years now, but she's still going strong...guess that's testament to the bearing quality!
Mine was a NPC Heavy Duty Cushioned Button clutch
I also got a lightweight billet flywheel whilst I was at it.
Total was about $1.1K i think
I got an exedy heavy duty in mine this year, was $1500 though.
this is where I got my Exedy HD..
the R33gts-t HD one a little cheaper than 1500 tho:
http://www.australianbrakesandclutch.com.au/
from their online store
http://www.ebay.com.au/itm/EXEDY-HEAVY-DUTY-CLUTCH-SUIT-SKYLINE-R33-RB25DET-ENGINE92-98-/321462983808?pt=AU_Car_Parts_Accessories&hash=item4ad8afdc80
and install well priced. that 500 quoted above about right,
(oh and if you call it's cheaper so they don;t pay ebay/paypal fees)
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
