When I had huge new NT05s 2nd was half decent, once they got a bit worn a old skate sesh.
Now I'm rocking dunlop 245s pretty good, holds 1st and 2nd brah. such grip. wow.
Edited by UNR33L
Depends what tyres you have I reckon. My setup was only just holding second when the tyres were new...I'd like to be able to put foot flat to the floor and not have to pull back on boost cause of wheelspin. 300 on E85 would be semi slicks and still break it in 2nd I reckon.
you run KU31's don't you...
I had traction through with 320rwkw and NT05's
On the front
Got R1R Proxes on the rear
Prolly not as good in the dry as NT05s but I bought them as a wet compromise cause NT05s are deadly in the wet lol
How big were your NT05s?
so much learning to modulate throttle needed.
do some track days and learn to drive it properly.
None of this street hero business.
speaking of business
Qantas Bushiness upgrade for tonights flight to Dubai..nice.
  • Like 1
Try the evo in the wet.
235 kinforests (im not even kidding) and you can launch it in the wet with traction through all gears lol
Granted is only 175kw atm but still it's spastic
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
