Have heard people just whack an eBay manifold on the Ford 4L and a GT35 and run low boost no problems
Would be pretty funny to try with an old piece of shit
Hmmmmmm intradesting I have my grandfathers old el sitting in our paddock :P
they do motorbike and misc. machinery... its all about getting parts really.
after speaking to our mutual friend yesterday, i dont think he's too keen on cashy's at the moment. the workshop will take em though.
after seeing the motor yesterday, needs a replacement crank :angry: (good thing i didnt go stroker kit)
dude... it took you 2 years to change a set of rims
that's cos it's my own car. Plus all monies went to buying apartment instead of unnecessary mods.
Well he builds all sorts of engines
He probably rebuilds an engine a day, not just high performance, lots of insurance ones. So i'd say he's dealt with a wide variety
so does he need engine out or does he engine out, rebuild and reinsert? The less car I need to work with the better. How does this work, do you have to put in an intro or do I just call him and be all like "Tony said deal with it"
Correct
Cash job just means you get paid for the service in cash. Amiright?
But is it tax deductable?
On a side note, I do have an accountant friend with a few years exp that might be interested. He just got married and is on honeymoon atm though...
unnecessary mods like fucking what? a pair of cashmere wheel changing gloves?
  • Like 1
He can do it all *if* he isn't busy
Best to just shoot him a PM, just say your from SAU and Tony told you to contact him through it
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
