Vic Wasteland Thread
R31Nismoid
125 for 4 days at bathurst, 55 for one day of WTAC..
it's an armature event with massive entry fees was expecting 20-30 entry.
and yeah flights were on points so free.
Not sure if should spend my flyer points on free flights or business upgrade
Seem to get more "cash value" from doing the business upgrade if you calculate the costs of paying for either in real money
Don't have enough points for the little mongrel girl to get her way
Martin, I thought as much...might give business a go so I can tell Pat it's not worth it on an empty A330 Perth flight
  • Like 1
But what about watch drift and show n shine? All the vendors and garages... I reckon itd be worth it.
At least cheer richo on. For shame.
You'd miss an event you wanted to go to over $25?
if I go have to take partner as well, and just turns into an expensive day trip
more so when we have Fiji in a couple of weeks and a house move as well.
plus having a weekend at home for first time in over a month is a nice idea.
Free market will dictate what the event is worth...if people think it's worth it they'll go and the event will keep running...if not they'll shut up shop as the numbers dwindle over the years.
Which is pretty much what happened to autosalon. Does anyone remember autosalon? Yeah, I bet you do.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
