AC 7260
I googled it while trying to fix it and it's obviously a VERY common problem to the point where msi are literally robbing people for the money they're charging for it.
How can a f**king high end gaming laptop have such bad wifi
The thing is f**kin useless to me now
hrm did you see this thread?
http://forums.whirlpool.net.au/archive/2241695
definitely looks like a driver issue, i'd be trying to find some of the older ones - or this
I just got these cards yesterday for a new-build laptop (Toshiba P75)
Initially I used the latest Intel drivers (17.x) and performance is 2.5 Mbyte/sec range which is terrible.
I uninstalled the drivers and it went back to the stock one in Win 8.1. Now getting 25 Mbyte/sec up and 23 Mbyte/sec down at close range. Pretty much the fastest I've ever seen on my WLAN at home.
Edited by UNR33L
I'll sus it out tonight... Was reading Intel forum this morning and it seems like it's a long running issue which Intel aren't solving in any of their new driver updates... If I can't fix it I've basically blown $2600...
inb4 should've bought a 15" retina display macbook
  • Like 1
Would've been better than this thing.
The laptop itself is fine but why a company as big as Intel would continue producing a known piece of shit wireless card, and why companies keep putting it in their systems is beyond me
What model laptop is it? Do you know if the wireless card can be changed over?
Msi gs60 ghost pro 3k
Sounded like it was the sort of laptop that can't really be modified /altered too much...
Shouldn't have to change shit just to be able to use the fkin internet on a $2600 laptop... It's 2014 ffs
You should be able to change it over to another card looking at the type of laptop it is, I can't find any disassembly guides for it though so can't confirm that. Unfortunately MSI aren't known for their quality control, for a gaming PC on that budget I would have recommended an Asus.
every mother f**ker in here was reccomending MSI... I'd never even heard of them til everyone brought it up, knew I should've went with what I know
Although so far the laptop itself is fine, it's just the piece of shit wifi card, which is intel.
If I sit next to my router I can get proper speed, but what's the f**king point of wifi if you have to sit on the router
I know it's not ideal and the laptop should function as is, but if worst comes to worst, you can get a netgear USB wireless adaptor. I used to use one on my desktop cause couldn't run cable from my room to router. Worked flawlessly, even playing games.
Most people on here don't know what they are talking about, when you have people like Hamish recommending laptops there's something wrong haha
Should have stayed with Asus. Guarantee within 6 months you'll start having overheating issues and things like the fans will begin to fail. I would see if you can take it back, you should not have to use an external card on a device that's meant to be portable...
Oh and I know Hamish is going to quote this but... if you had similar issues on a MBP you could take it to the Apple store and get a new replacement the same day haha
Yeah but you have to make an appointment to speak to one of those arrogant, cocky, shitty joke making hipsters aka a "genius" and frankly I'd rather eat my laptop after taking a shit on it
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
