I stand corrected.
Presenting the gangsterest mother f**ker to emit wifi
http://www.centrecom.com.au/netgear-r8000-nighthawk-x6-ac3200-tri-band-wi-fi-router-
Will buy.
nighthawk x6 or gtfo when it comes to wifi routers these days. Wait for sales. They drop to $270ish. Officeworks will price match.
Yeah but thats coz it's old as well, so it works well with the old router telstra gave me... It's wireless G...This card can connect but doesn't work at it's potential with an old router, so a new router should fix it...My parents have a wireless-N router here and it's working fine...was working fine at centercom too...
Telstra want $216 for their AC router, that porno bad boy is $339....Once I've seen something I want, it's very hard for me to buy a lesser product lol
ive got the telstra AC router and the older N router. The N router modem gives me faster internets so I offload routing to a nighthawk
That what you run birds isn't it? how you rate them?
Was also looking at invos..
Nah I run Toyo R1R...bit more exxy but they are an all weather rather than summer semi
Have you considered something in the cisco range? Not that expensive when you look at the long term benefits....
Would also need to purchase a separate unit to do wireless though...
  • Like 1
Cool. How come you went with 265/40 instead of 35?
They grippy?
Yeah I brought the wrong ones so dont fit at the front only rear lol
Grippy enough for my power. Havent tracked them yet tho, but I hear its up there with the ad08s
look if we have kids I will be re-evaluating my job for sure.
but for now. why would I.
now Katie's back is good again, get her to come on a few work trips with me will be even better.
trying too hard for kids?!?
  • Like 1
Fuark I think I just heard some guy's asshole rip apart in the cubicle next to me
Massive explosion and bombs dropped followed by the sound of...sobbing/crying? WTF
Then using what I suspect was the toilet brush to push it all down while flushing
  • Like 1
genuine lulz
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
