Thanks martin.
I wonder how to specify an item if there are 2 with the same part number...
Coz ornament on the left much better than the right.
They don't have the same part number, they have the same part code. You gave it a part number an it'll tell you what part code and model that correlates to. You go in and grab a part number it'll ask you which one from that part code you want.
Grille Ornament Part Code 65851 relates to
65892-AG000 Cedric Ornament
p1.jpg?ct=7a9ed1926f97
65892-AG005 Gloria Ornament
65892-AJ000 Gloria Badge(Offered for facelift cars)
Nah mine doesnt... Just has nissan badge on grill. Friends one has badge and looks bawse.
Imma de-badge it front and back, with only bonnet ornament. Probably get pulled over regularly... Need to make sure i have 15% tint for that extra stealth
...wonder what else i should get if paying postage from amayama... Already got CVT service kit, getting hood ornament, dont need any oem pulsar bits...
lol Jono I remember your hayfever
Feelin it today too bro, nearly a box of tissues down
Nose was runny for whole 3 hours of mowing today. Not the thick runny, the watery runny.
Abalon A eyedrops, best thing ever.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
