Spotto at Knox shopping centre police demo. /subtle
Bt1
Drove past the bloke that was driving that thing on Saturday. He had a cop uniform on and there was a highway patrol car 2 cars behind him.
Oh well there you go, i was always under the impression chasers were close to 1900kgs. The y34 was shipped for 1680kgs
The green leds through the passenger windows is so awesome. Will need to put on some green undercar neons to complete the look
or you could spray a huge penis across the side for the same effect, but less money
  • Like 1
Yeah they do that
Had some f**k heads come up quickly behind me on the west gate freeway the other day, obviously on the way back from the GP. They weaved in front of me and then one (on L plates) slows down to 60km/h in front of me talking to his/her mate in the lane next to us, then I change lanes to move around them and the biker looks at me like I've done something wrong lol? Then does the shittiest wheelie I've ever seen. f**k heads give the rest of us a bad name. Can only hope they take just themselves when they inevitably end up a road trauma statistic.
I had a bunch of wankers on road bikes surround me on the Neppean Hwy one night in the 33. Boxed me in and forced me to slow to like 40 while their mates did wheelies and shit.
They tried it on a second time but when I stepped it out at 100kph they decided not to come too close lol
edit : csb
  • Like 2
edit : csb
As a biker I can't stand how arrogant, self righteous and hypocritical so many bikers can be. The worst are the ones who engage in road rage with cars thinking they can come out of that battle on top.
CSB warning. I remember when I was driving Alvin's 34 and I had a motorbike swerve into my lane and put on the brakes hard, which made me slam on mine, then he changed lanes as I did and put the brakes on hard again; this time his rear tyre connecting with my front bar (put a rubber mark on front bar that polished out easily enough) and he looks back at me like I'm the one driving like a moron. He then slows down to let me pass and starts tailgating me really close with his high beam on. I'm loling cause the dick head is playing traffic wars with 1.5 tonnes of metal...I tapped the brakes a couple of times to scare him away and he quickly got the hint that he would end up second best if he kept it up. He got the bird when I turned off, cause that's how you finish off a situation like that.
Impul bits including ECU are still available
Duuuuuuuude... How did you find about all the impul bits? That ecu is a great find.
Yeah heaps of coilovers and modified air bag kits on YJ.
Good way to blow your engine, as all the protection of the stock ecu is bypassed.
Plenty of Stagea engines down the drain from the Impul. Bump the boost up and see what happens. At some point the stock injectors max out and you are screwed. ;)
At least the Nismo ecu has protection. Are they available still or discontinued?
Yeah just did some reading up on it and not reprogrammable, so not interested.
Theres no nistune as far as i can tell, but would an impul chipped ecu make it possible to use nistune?
Ive spoken to uprev but i cant give them all the info they need (yet)
I doubt uprev will work, they couldn't help with ours after sending them the ROM file.
Nistune were useless for the VQ25det, but they do have the VQ30det early ecu's cracked.
I would say you are stuck with an Emanage over the stock ecu, (or over an Impul/Nismo ecu to get rid of afm cut/speed cut) with a decent tune.
Yeah i know about the biggybacks. NM35 ecu pinout is same shape as y34 det, not sure if many of the pins are common. If i do want to go down the E85 route, might have a word to Wolf ems since they have done a wire-up for an auto 25det stagea
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
