anyone know how to time yourself at an untimed event?
mates doing sandown. untimed event.
theres probably an app you can get for your smartphone, not sure how accurate or reliable it would be though.
could always have a mounted go pro and check the video later at a certain spot for times? again bit of a guess & hassle but would give you a pretty close idea..
Download RaceChrono for Android...
Pair it with an external 10hz Bluetooth GPS like a Qstarz BT-Q818XT stuck to the top of the windsheild if you want anything resembling accuracy (as a phones inbuild gps isn't going to be able to update fast enough, especially down low in the car (pocket or glovebox or center console))
Add Sandown to the list of "My Tracks"
hit "Start Session", then drive.
+ 1
Its accurate to within tenths of the actual natsoft times.
I also mount the phone onto the dash so i can see live sector and laptimes
Have it in the car and concentrate on the stopwatch while doing 200 down the main straight...
What?
It's no different to quick look at the gauges while doing 200.
  • Like 1
Yeah I'd rather not click a stop start stopwatch when on a race track.
What?
Again, it's no different to switching lights/indicators while doing 200+ km/h anywhere really. Won't cause you to lose control and heading for armco barrier or concrete wall.
What?
I darno mate
You dont have a great track record :/
  • Like 1
You land vaginas need to ride a bike at 250+ for some perspective
Or watch youtube footage of nutters doing that speed.
Or watch crazy goat lovers doing 250+ in highway between Istanbul and Ankara, while being followed by couple of BMWs driven like its stolen.
I darno mate
Therefore you'll be fine with a $2 stopwatch. Cos you're not me.
Edited by Count Grantleyish
I'm not saying it can't be done it's just not preferred
And I would prefer not to do it, same as every other track day car, haven't seen one driver go out on a hot lap and time himself with a stopwatch in the events I have been too
  • Like 1
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
