3" fujitsubo legalis.
im wrapt with the power though.
My 3inch wasn't even a 1kw restriction when we tested at 320-330rwkw on 98 octane.
And wasn't a restirction at 380rwkw on E85
Just sayin
  • Like 1
Not all 3 inches are created equally
Moh are you running a cat...if so, ditch that...
Cooler piping and cooler is always an obvious one
Intake pipe sucking shut is never good
Sometimes the turbo you've chosen can have a restrictive exhaust housing particularly if it's a responsive turbo and gets choked up top
That power is plenty for the street, hit up E85 and be laughing
i do have a decat.
ill throw some intercooler hardpipes on this bitch when i can.
wouldnt be intake pipes, george is making about 400kw with stock intake pipes and cooler.
my problem is i dont want a cannon, and all the free flowing exhausts are cannons.
also will need cam gears, and may go for a set of cams while im there. because mohsen.
but most importantly, ill have to drive it for a bit and get used to it.
Don't understand why workshops if they say its an exhaust issue, just don't quickly test it by dropping the exhaust. (As long as the customer is happy to pay for the extra time)
Would suck for Moh and other customers if they bought a whole new exhaust system only to come back and have the exact same issues
i do have a decat.
You have 707160 -9s yeah?
Should make 300+ at 18 especially with rebuilt motor.
they didnt say it was exhaust, not sure whats up. the car has been an absolute bucket of shit.
my first build experience has been nothing but a nightmare.
just random shit that shouldnt have happened. eg: f**king vac leaks everywhere.
You did replace every vacuum hose on the engine while it was out though? Right?
Generally Fujitsubos have a narrowed down part of the piping just before the rear muffler to keep things quite despite being a 3" system, even their cannon systems have this
Also 2nd spot of the new falcon today (first on saturday night at ribs & burgers in Cragieburn)
Digging the bronze colour much more than the blue, looks more like a BA/BF shape again though
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
