I work for a dutch company, can confirm insanity levels rising.
I hear those western australians are pretty nuts as well...
My partner is half Dutch and from WA
Havent met any maltese ladys that werent family. Cannot comment.
Yes you can
They even admit it themselves
And both Maltese mates of mine have admitted their mums are off the charts, a sandwich short of a picnic
Yes you can
They all blame menopause though.
You cant really argue with that, but you want to
http://www.eventfinda.com.au/2014/3rd-annual-macedonian-food-festival/melbourne
Apparently there is a rival Macedonian festival being held in Williamstown on the same day. Should give you some insight into how bitchy they are lol
Car is going well, could do with a bit more powah / noise but that's not far away
What you planning? and what's it cost
What's the stock rwkw of those things and how much improvement are you going to get?
I've looked at the 4 door 335i bmw's but they are quite ugly compared to the 2 door equivalents
Yes but that's the loophole
Maltese females are 24/7 going through menopause. They get one period at age 12 and then bam, bat shit bitch for life
The new current shape 4 door is hot the old one though not so much
How's German life ric?
Ahhh yeah i get in there before that
Exhaust, tune, and enough boost should yield anywhere up to 300, that'll keep me entertained. Not sure about stock power, maybe 180 or so. It's massively held back from factory
Feels good Alex, cops / other hoons seem unaware which suits me fine. Trying to fly under the radar after the theft
Found that rental for me yet Alex?
Nah not much cheap going around here depending what you wanna spend Id investigate waterline in Williamstown new development of apartments hot location long settlements can't go wrong
Trust me I'm a salesman!
Have you got dual clutch ric?
Drag birds when youre done.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
