I work for a dutch company, can confirm insanity levels rising.
I hear those western australians are pretty nuts as well...
My partner is half Dutch and from WA
Havent met any maltese ladys that werent family. Cannot comment.
Yes you can
They even admit it themselves
And both Maltese mates of mine have admitted their mums are off the charts, a sandwich short of a picnic
Yes you can
They all blame menopause though.
You cant really argue with that, but you want to
http://www.eventfinda.com.au/2014/3rd-annual-macedonian-food-festival/melbourne
Apparently there is a rival Macedonian festival being held in Williamstown on the same day. Should give you some insight into how bitchy they are lol
Car is going well, could do with a bit more powah / noise but that's not far away
What you planning? and what's it cost
What's the stock rwkw of those things and how much improvement are you going to get?
I've looked at the 4 door 335i bmw's but they are quite ugly compared to the 2 door equivalents
Yes but that's the loophole
Maltese females are 24/7 going through menopause. They get one period at age 12 and then bam, bat shit bitch for life
The new current shape 4 door is hot the old one though not so much
How's German life ric?
Ahhh yeah i get in there before that
Exhaust, tune, and enough boost should yield anywhere up to 300, that'll keep me entertained. Not sure about stock power, maybe 180 or so. It's massively held back from factory
Feels good Alex, cops / other hoons seem unaware which suits me fine. Trying to fly under the radar after the theft
Found that rental for me yet Alex?
Nah not much cheap going around here depending what you wanna spend Id investigate waterline in Williamstown new development of apartments hot location long settlements can't go wrong
Trust me I'm a salesman!
Have you got dual clutch ric?
Drag birds when youre done.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
