Exhaust, tune, and enough boost should yield anywhere up to 300, that'll keep me entertained. Not sure about stock power, maybe 180 or so. It's massively held back from factory
Feels good Alex, cops / other hoons seem unaware which suits me fine. Trying to fly under the radar after the theft
On my old 335i, I had:
JB4
Downpipes.
Air filters.
Charge pipe.
Meth kit.
That got it to exactly 300rwkw. If you have the n54 engine, just get ready for HPFP and Injectors to die lol....
Nah not much cheap going around here depending what you wanna spend Id investigate waterline in Williamstown new development of apartments hot location long settlements can't go wrong
Trust me I'm a salesman!
Have you got dual clutch ric?
What kind of rent prices are they looking at their Alex?
To be honest I don't really care where or what I buy, as long as the rent I get is decent, and it's newish so I get the tax benefits (my understanding of that aspect is limited, but from what I've been told, newer the better)
Budget would be up to about $400k I'd say
multi million dollar apartment, kgo
Nah I've got dual balls so bought a manual ;)
JB4
Downpipes.
Air filters.
Charge pipe.
Meth kit.
Already replaced under warranty thankfully! How'd you find it at that power level?
JB4
Downpipes.
Air filters.
Charge pipe.
Meth kit.
Nice
If the 4 door weren't so ugly it would be on the consideration list
Not sure man it's not my core area but it's blue chip so I think you'd get a decent return
Very good.
Power was linear and it was a fair bit quicker than the e93 m3 that I replaced it with.
Best of all, it wasn't too expensive, all up it cost around 3 to 3.5k including labour.
Nice
Yeah the e90s look a bit dated now. That said I've seen some nice examples...
  • Like 1
Decisions shouldn't always be around tax
Just because you get about 30cents back for ever $1 you spend doesn't mean you always should
Know what I mean jellybean
  • Like 1
I'll speak to Jess about it... she was gonna handle my rental anyway..
Not really, no.
But yeah obviously there's more to it than tax benefits...but if the rent is a good amount, and there's demand to rent there, then in theory it should be ok..
Rental prices dropping in clayton.
Went from house on half-block in clayton to same size house on bigger block + outdoor area and garage in rowville for $50 less a week.
Old house was on the market for over 6 weeks and had to drop $20 a week to fill it.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
