seems I got one this month already.
so we had 10% bonus per year for years.
previous CEO decided was a bad thing
so they removed the bonus and boosed every-ones salary by 10%...nice
new CEO starts...want to motivate staff, so adds 7% to every-ones salary as a bonus...
(after firing 10% of staff)
all in 12 months!
Ask for another one.
birds fears nothing.
I'll go to Alaska, bitch slap a polar bear and take its food
I'll mow the f**kin lawn on a land mine field
I'll scratch my back with a chain saw
I'll head butt a f**kin unicorn
I'll drive a f**kin truck through Ethiopia talkin about free ice cream sandwiches
I'll receive an operation on my eye ball while riding in a dune buggy
I'll sneak up to slick rick and snatch off his eye patch
I'll start a record label and base everything I got on MC Hammer
I'll go to a big ass beehive on a tree drop my drawers and hump it
anyone stayed in portarlington over the peak holiday period?
im hoping it doesnt become the northern suburbs like rye does lol/
theres some fun to be had down the peninsula in the summer.....
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
