Varex converts know
Scotty how hard would it be to fashion up something like that, e.g. valve on the side of a front pipe that opens up or will that make it flow horribly?
The hard part is to find a valve that seals properly.
Or just bolt a plate over a flange, and remove it when you want to annoy your neighbours.
Yeah an exhaust leak under there, even slight would sound like shit.
Plate not a bad idea for track days etc. Waiting for exhaust to cool down before you can remove it / put it back on, not so cool.
nah too many track days have noise limits now, nearly need to be quieter than street!
3.5" exhaust with a decent muffler, no cannons unless i have absolutely NO choice.
what do you more exprienced homies recomend? how can i make this sound like its going to bust into your room and eat your soul?
like AAHH32
Magnaflow straight through muffler. Very quiet for straight through. A cat would bring mine close to legal limit (sort of)
they all the same design, just different shapes/diameters.
speaking of which... need help VWL. muffler tips... got a big ass void to fill and not sure which direction to go. want classy but needs to fill 25-28cm wide gap.
10815169_10203216252783509_945084838_o_z
only example i know of, did twin staggered pipes. looked pretty hectic drifto.
dual square?
Reckon that dual square looks classy, if not then the second dual even round.
Third one withthe angle tip seems too dori dori.
That's my 2c but then again, who am I to speak. I've got a cannon... :unsure:
Sooo tempting to buy this and give scotty a call for help :D
http://www.intunemotorsport.com.au/FG-5.0-lt-GT-and-GS-sedan-mild-steel-3-inch-cat-back-system.html
Dam you houses/apartments why you got to bust my grill.
Anyone know what rims these are in the video?
Edited by UNR33L
Dafuq
Ridiculously fast 4G at Melb Airport, I must be right next to a phone tower
Test Date: 28 Nov 2014 11:32 pm
Download: 68.86 Mbps
Upload: 8.69 Mbps
Ping: 21 ms
Connection Type: Cellular
Server: Melbourne
Could fkin game very well off that; that's better than my cable extreme that I used to have :/
Where my fkin Xbox
  • Like 1
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
