Vic Wasteland Thread
R31Nismoid
Borci made the mistake of taking out his girlfriends father in his GTR and overtaking the Ferrari... Because nothing says "Your daughter is in good hands" like travelling 200kmh in the same car you come pick her up in
lmfao <3 borci
I should do that... My gfs dad thinks his 135i is faster than the pulsar. Convertible does not equal more killawasps
Lol if the gfs parents knew half the shit I've done with her in the car / on the bike.. pretty sure I wouldn't be allowed back in their house
Same as Leeroy, they have a maz 6 sp2.5 or what ever it is and think its fast - thats cute :P
Yeah I'm sure we're about to have some redundancies now that east-west link isnt going ahead, we'll (CAT) be missing a lot of work I know they have been hanging out for that a long time.
My pop thought his 6 cyl EF Falcon could do 0-100 in 5 seconds, so like everyone else on SAU I had to bring an older generation of wishful dreamers back down to earth
Achilles tyres, do rate for the price that's for sure. (at least in a straight line, yet to try and put any power down around corners)
Now I wonder what the wear will be like in the near future.
Birds any news on your bike? what you looking at getting next? 2015 r1 do ittttttt
Edited by UNR33L
    • So what I hear from Rob and Mark is, Matt needs to stay the hell away from your places when you choose to do cleanups, for fear my hoarding will get worse, as Ill likely find things to suit some of the projects I want to build... As for ditching stuff like Mark does, I wish I could do it so easily mate, but lots of my spares are for the R33 and I'm slightly attached to them...   However, I was staring at the pile of subs, 2 for the car, 2 for a home audio system and thinking I'll likely just ditch those... That's. A lot of space back...   I must hurry up and finish the Subaru, and then the skyline... That's probably get some space back...   But my main take away is, other than big plastic tubs, and some sort of categorising what you have in each, no one has found a good solution, that takes up the minimal amount of space possible?   And Rob, I've been wanting a mezzanine, and have been tempted to put one in, but I'm borderline not enough height, and secondly, I hate heights! (No good spot for stairs, so it'd either be fold up stairs, or a ladder, of which I hate ladders and can't carry the bigger stuff up).
    • If they are a standard parts that have been replaced with a new, or better part, they mainly go in the recycling bin at home if there's room, or into the metal or big rubbish bin at work Saying this, I have gifted or sold some random stuff over the years, but, if they don't sell, or aren't given away within a month or so, they hit the bin I use to keep everything, to give away when I sold a car or bike, but typically people didn't want the parts, and the garage, shed, and other storage areas would fill up with parts, that got old and keeping stuff for the sake of keeping stuff was not the best use of space I do still have a big box full of all sorts of nuts, bolts, washers and brackets though, which come in handy... "every few years" and typically only for other peoples projects
    • @Duncan for the antennas for the 4G booster, send me a photo of the connection type it uses, and what sort of bands it picks up on, and a photo of the existing antenna itself. I have some interesting ones coming into work soon that may suit your needs really really well AND stop you drilling holes in the roof.
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
