House parties are the way to go, or in the loungeroom at home with a scotch and an ironic 45 on the decks you spun 10 years ago back when you were mainstream and uncool.
this any time.
think will drive up the country and have a few beers with my mates this year, shed party...
East west link would be alright, but using it to drive to my job where my hourly rate has just been cut in half, along with everything else they want to strip us of, not so much.
I didn't hear any of this from liberal ... Was this Union scaremongering?
This was my point.
Labor scaremongering would have you believe the Liberals will decimate the state like Skynet in The Terminator, where "big business" will destroy everyone but themselves
Liberal scaremongering would have you believe the Labor will decimate the state like the Tripods in War of the Worlds where "the unions" will destroy everyone but themselves
It's the same shit, just a different title.
I cant believe people actually fall for it.
anyone that voted for labor, just because they will scrap that tunnel is going to very disappoint.
as if a political party backed and controlled by unions is going to cancel a major construction project.
heres to the east west tunnel opening maybe 6 months later than it would have under the libs.
I suspect those people largely voted for the Greens... who continue to trumpet their own relevance despite holding probably 1 of the 88 seats in the lower house
dont get me started on those idiots.
f**k the people save the enviroment.
as liberals would not have had a delay..
oh wait I hear what about the nagambie bypass, delayed over a year...(sorry this was the most recent I could think of built in past 4 years)
built under the liberals.
burnley tunnel.
massive issues had to be closed and repaird
built under labour.
seriously they as bad as each other
  • Like 1
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
