Maybe try some A050's , though I've heard they're not very good in the wet either :rolleyes:
ao50, if the road isnt like a lake, theyre awesome in the wet.
also. wtb. security guards.
Dat Taga prepped 34R was pretty farken planted on the deca skid pan that super wet deca last year where the skidpan pretty much was a lake lol.
Also, just bought another RS this morning, flying to Shitney Saturday to pick it up
One day you'll have an RS actually on the road... and that day shall be sweet
Well, he had one on the road.
I'd know cos I raped the clutch a bit.
Nah I'm probably going to revert mine to stock and sell mine, this one cost me pretty much the same coin and is far tidier, also has sunroof.
whats not stock about yours?
didnt you do this with the last RS you had? (except was damaged) whens it going to stop miguel, when is it going to stop?
gc8 4 pots, gc8 susp, gc8 steering rack, whiteline alk, resonator deletes, 3"tbe, f&r strut bars, koyorad, alloy rear swaybar c links. Will all make their way onto new wun whiteline f&r swaybars it already has. stock bits onto grey one.
This will be the end... curent one was supposed to be the end too but they're so much car for the money gaddamit.!
its like we're losing you Miguel. Enough is enough.
Depending on insurance situation and love for the vehicle of course...
The missus had third party fire and theft on it so it's covered for 3 grand worth of damage. Luckily I was on the policy so I could sort stuff out without her here. Fingers crossed it's not written off but they did a nasty job inside the car.
She loves the car though so it's going to be rough breaking it to her when she comes back from her cruise tomorrow.
Our lease is up in Feburary so I think i will look at a better suburb. Didn't really do too much research when we first moved here at the start of the year.
I tried that and had my car stolen lol, good luck brah Edited by HEKT1K
I'd do one for my R33 but it'd just bounce up and down too much to make sense.
Hell it's dropped 3 times since I've owned it, and when I bought it in 2010 it had "84600" after being imported with "54000" in 2006.
Yeah ok....
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
