f**k you guys, Ricciardo is a mad kunt. I've even worn a themed tie for the occasion
All I see is a corporate wanker with a tie clip.
What happened to keeping it real? City office politics must be a headf**k.
#nohate
Needs more singlets #fiifo
I was at a family gathering when someone just got back from thailand, giving out gifts to people.
"You better not have gotten me a Bintang singlet"
"Nah"
"... Or a chang singlet"
"Nah"
*opens gift with singha singlet inside*
ead lololol
  • Like 3
#nohate
I dress this way cos I like fashion... not a whole lot of office politics in the public service
Come at me you bogan
how about a turbo tie:
http://blipshift.com/products/turbo-tie
or a shifter tie:
http://blipshift.com/products/gearshift-tie
http://blipshift.com/collections/accessories
I've made the call that I refuse to wear a tie...unless job interview.
or a shifter tie:
Subtle. They're not bad. But Db5 >
Exactly. If you have nice things they will probably get stolen no matter where you live.
Unless you live where I do and had a "friendly" dog
lol:
Guy Goes To Mexico To Kill Himself, Spends Week Doing Coke And Banging Hookers, Decides To Keep Living
http://totalfratmove.com/guy-goes-to-mexico-to-kill-himself-spends-week-doing-coke-and-banging-hookers-decides-to-keep-living/
Hahaha saw that a while ago, would do it just for the sake of doing it
haha nothing wrong with fashion.
discussion point: if a workplace culture condones the use of designer tie-clips, this may allude to the point that business-attire could be a factor on the judgement of colleauges. (excluding colleagues who deal with external clients etc)
May not be an issue in your space as mentioned but could be in other places.
Have always worn company issued uniforms for both Site & office along so never had the issue.
However where ones uniform is prescribed, the stand-out factor is usually the flashiest watch.
then this is the watch you need:
http://www.hsjewellers.com.au/blogs/news/15499832-pulsar-v8-supercars-limited-edition-watch
Meh... casual workplace here... I just wear neat casual... Jeans and a nice top or jumper... Shirt if I feel like it
There's nothing customer facing out this office at all so that helps
Can this be used to time how long a freshly built SR20 will last during a track day?
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
