I didn't say anything about dressing like a homeless kunt, but if the fact you don't wear/can't afford a $3000 suit means you don't get a promotion over the sexy Ric looking mother f**ker at your work, who isn't as good at your job as you are, then your corporate world can smoke me.
so my most expensive suit was about 400ish
was bought for the wedding
now use at customer sites
good value
my first from this tailor finally wore out, probe 4-500 wears for around 200, ordering a exact copy when over there next year.
I don't think Ham or others are suggesting that. Just saying that appearance is important (we don't ever see you dating anything other than gorgeous bitches now, do we Monica)
The dress thing is more a factor at the shabby end of the scale imo; once you put in a bit of effort and meet that hurdle requirement, you don't have to be rockin brand name shit to get ahead
You don't see me dating anyone....
I'm not half as sexy as you
You're right, you're at least 3 times as sexy as me.
  • Like 1
In Dezz' defence, the context of the discussion was in relation to fashion/tie-clip & expectations within the internal work-force.
However Ham further clarified that his comment 'dress for the job' was in regards to meeting a minimum level of dress-code rather than tie-clip promotions.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
