Vic Wasteland Thread
R31Nismoid
I didn't say anything about dressing like a homeless kunt, but if the fact you don't wear/can't afford a $3000 suit means you don't get a promotion over the sexy Ric looking mother f**ker at your work, who isn't as good at your job as you are, then your corporate world can smoke me.
so my most expensive suit was about 400ish
was bought for the wedding
now use at customer sites
good value
my first from this tailor finally wore out, probe 4-500 wears for around 200, ordering a exact copy when over there next year.
I don't think Ham or others are suggesting that. Just saying that appearance is important (we don't ever see you dating anything other than gorgeous bitches now, do we Monica)
The dress thing is more a factor at the shabby end of the scale imo; once you put in a bit of effort and meet that hurdle requirement, you don't have to be rockin brand name shit to get ahead
You don't see me dating anyone....
I'm not half as sexy as you
You're right, you're at least 3 times as sexy as me.
  • Like 1
In Dezz' defence, the context of the discussion was in relation to fashion/tie-clip & expectations within the internal work-force.
However Ham further clarified that his comment 'dress for the job' was in regards to meeting a minimum level of dress-code rather than tie-clip promotions.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
