so, work shop i know of, that my car once sat at for a couple weeks got raided, and was full of heroin this morning......
At least we now know why your coilovers are so tight... its been modified to carry gold bars and bricks of heroin
They're digging up the back yard to look for potential stashes, so it actually is earth shattering
U r 1 cheeky kunt m8
I remember meeting the guy from that shop once lol
Edited by HEKT1K
Are they supposed to be any good?
Yeah, like 15 years ago :P
I had 10 year old Tein HA's on my old 33 doe(Last version with the gold pillowball tophats). They were in awesome shape when I got em. 7kg springs all around, stupidly stiff on the hardest damper setting but pretty comfortable on lower settings. Ended up selling them for the same coin I paid for them too.
What'd you think all these asians were paying for all these mad cars with...hard work?
Heard about that. Epping? Only a $6m haul, nothing earth shattering
Not when compared to your pay packet
Going to one of these cook your own steak stone grill joints tomorrow
I still don't see the point to this shit... I go to a restaurant, pay for a steak and have to cook it myself... Pretty sure I can do that at home
  • Like 1
Used to say that before I tried them, but am a changed man. Can't guarantee it'll be awesome unless you're going to Paesano, but...
Steak stays hot throughout meal, comes out very quick, steak remains very juicy throughout even cooking it well done, don't have to clean up anything afterwards or prepare, pretty well guaranteed a good cut cause they can't hide the appearance by cooking it, yada yada yada you'll wake up tired the next day.
I've never had a steak go cold on me, apart from the 1kg challenge I did...
What if you're no good at cooking steak...?
And if you go to a good steak restaurant /good restaurant in general, your steak will be juicy
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
