Did lol.... at:
Hamish getting mad bro
Realising a 2.2L is bigger than a 2.0L and there's near 3 times to power output from the little baby evo compared to the 5S-FE
The commodore because it looks like a decent burnout car and not a street skidder's first time at an event...
Hipster Lumberjacks complaining about the lack of nuttiness in their $9 mocha soy latte
Yeah, I've been on many a different Dyno...
Chequered Tuning
Chequered Tuning
Chasers
Chequered Tuning
RTR
RTR
Racepace
Not wanting to get involved in this jerk fest... but yes... one did read quite a bit higher than the rest. But at the same time, different tuners work with very different styles of tuning...
But... car was pinging on trents dyno and I NEEDED it for a DECA on the weekend so we pulled it way back for a "safe tune" of 230rwkw... a few weeks later (no mod changes) it pulled 212rwkw on RTR (Simple retune and it was back up to a safe 242 (which I'm estimating 260 on trents)
The only real reason I don't go back to Trents is because its too hard to get a hold of them and get a tune within a week of when you need it. Too hard to plan mod installations etc if you're not even sure if you'll be able to book in some dyno time before a track day.
  • Like 1
Spied a black 32 gtst on Center Dandenong Road with SAU Stickers this morning near Moorabin Airport as I was getting coffee on my way to work, Pat?
Surely its the only one left...
Haha unfortunately not. Just dropped off car at traction tyres for some much needed lows.
In before Xmas defect.
There is a tuner in SA that uses a hub dyno and massively over inflates his figures which has been the source of much controversy over the years, however this is due to the tuner and the correction method he chooses to run.
Leigh and Birds just run with it in VWL purely as a jimmy rustling exercise.
Oh I love rustling jimmies left right and centre, but I legitimately believe there's a significant difference between Trent's power figures and roller dynos. Have seen too many of his customer cars produce different results elsewhere at several different places, and no one in the country seems to be able to replicate mr HG's turbo results, except those who get their cars tuned at Trent's. It doesn't say anything about the tuner, unless they are in denial of the power reading difference.
The only reason I get rustled over the differential is because people masturbate to a 350kw run, talking about how responsive it is for so much power, when the thing would make 300 everywhere else. That and these people whinge when they go to other dyno days and are down 50kw, saying it's a shit dyno that must read low cause they lost all their power. Case in point: our SAU dyno day at RE customs 4 years ago.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
