All I'm hearing from people regarding times is "It was an untimed day"... as if they weren't running RaceChrono on their gold plated iPhone 8s 512gb
Though... I wouldn't be bragging about speed either if I was making 230kw on E85 out of an RB26...
  • Like 1
Haha they all had go pros. Mounted everywhere. Surely they know their times.
So I was taking a pic of moh and notice iron Mike had actually hired a model to take pictures on his car. At driver dynamics learning day.. a model.
So much gays
was this before or after moh ate her?
landed in melbourne on saturday to 40 degrees.
was quite bearable.
thanks cairns.
Bet it was better than when you were in Iraq, Afghanistan and Vietnam at the same time battling 4 armed mutant insurgents in 85deg heat doe
  • Like 2
The e85 monster was having its ass handed to it by an a45 amg
A45 AMG is pretty quick though!
In saying that 230kw on e85 on the r34GTR
Probably similar power to weight to the tuned stock turbo'd R34 GTT which makes 200rwkw at around 1,400kgs
But dat r34 gtr doe #race #rb26 #gloves #e85 #race day # race helmet #security guards #fastest car # most exclusive car
  • Like 4
I don't think there would be a huge demand for recriational travel to recent and current war zones
thats right, too many people been there before for you eh?
yeah not sure I would be following his advise..
your definitely not our demographic martin.
  • Like 2
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
