also, bought car with cooked motor, you just did a mohsen.
seriously now.
do LS TT
no... buying a car with a blown motor would only be a mohsen if the motor blew on the drive home
Still deciding, it will really depend what comes up. If a built 26 pops up, I'll consider that for a cheap and risky way out. Otherwise, budget may allow for RacePace to rape my wallet.
Was making 340awkw with the HKS turbos before engine issues (it's actually still quite driveable and the engine idles smoothly besides the sound, so don't know how far gone it is), which sounds plenty for me in a street car. I'd like to put it on sugar cane for response, though.
On the cosmetic side of things
This was a very nice 33R at Sandown on the weekend
10917414_697478720373864_108591382654288
10917109_697478693707200_424280051460900
Thanks gents
It's gotta get to Melbourne first and that was an absolute nightmare organising transport on the day I was supposed to be flying back :O
Transporter knocked it back cause needed 15cm ground clearance so I had to remove the front lip and leave it in ACT...no biggie as it was damaged anyway. Took off the brake ducts too but they are with me.
Chuck a thicker oil and she'll be right moite.
I've done my share of interstate car towing...prolly would have if I still had access to a race car trailer and time wasn't an issue.
$400 depot to door from Canberra, pretty happy with that.
  • Like 1
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
