Vic Wasteland Thread
R31Nismoid
neo head, 26 bottom end. 26 manifolds, best of both worlds.
That involves more effort... I'm talking just getting a s2 25 AWD from a stagea and dumping it in as is.
Will cost $1k + labour and most importantly look like a 25 hence providing epic fanboi butthurt
Mike likes to over complicate things.
Need to smash the mantra of KISS into his head.
We don't think it's done any other damage, can't find remnants anywhere else. No bearing material floating around and bottom end APPEARS fine from a wiggle and inspection.
Pulled out onto riversdale road and gave it a little bit in first gear, went to change at about 5k rpm, looked down mid change and saw light was on and gauge was at 0 so turned it off and pulled over.
I have a feeling that pulling out and crossing over but still driving parallel with the tram tracks is what did it, all the wheels having different amounts of grip. Started raining 5 minutes after I pulled over too just my luck! It's a standard pump, getting replaced with an N1. I know it's not an amazing replacement but I'm not spending a grand on a Tomei pump, and this brand new versus an almost 20 year old standard pump, should be fine!
It's also getting a sump baffle extension thingy, kinda like the Tomei style with trap doors, only its an extension welded onto the standard baffle.
Oh and did I mention -7s! Hnnngggg
I'm about a second or two slower than you on most tracks, I don't know how to drive yet though...
Will be repairing intake manifold gasket and switching to E85 to squash these detonation problems before the next day.
Got a wedding on the 31st of Jan, so no Philip Island WRX Round 1 for me... :( Was hoping for a late summer PI
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
