I had the chance to put BioFuel lines in my car today with the engine out, opted not too because you're right, it's not needed!!
Not gonna lie, it looks like my first car hnnngg..
I don't know why ethanol is seen as any more corrosive than petrol.
Is it, Alvin?
Either way, 90s Skyline lines can take it and most fuel injected fuel lines should be able to, unless they are crumbling away.
Remember the Brazilians have been using this shit for decades in the same or lesser cars and would probably laugh at the superstitions floating about here.
A mate of mine has a few petrol stations and even he thought the stuff was evil for whatever reason, til I showed him my dyno graph before and after! Now wants to run in his race cars :)
aye ric
http://www.ebay.com.au/itm/Vl-turbo-/141531162467?pt=AU_Cars&hash=item20f3ea2763
lets go halfies, slam it on its guts, with a fat as f**k dose, just cruise around and flutter bitches.
That this thing is advertised for the same price my GTR was, is disgraceful.
Is it, Alvin?
Did a proposal for a biodiesel start-up for a business owner during uni. End result was that rubber hoses beyond 1975~ can handle ethanol. (I vaguely remember that natural rubber would degrade in ethanol) Only watch out was that ethanol cleans your fuel system so best to change fuel filter after a couple of tanks to prevent any blockages.
However this was in regards to switching from dirty diesel to biodiesel in trucks so shouldn't be an issue from ULP to e85
Easy way to test is grab an off cut of fuel hose and leave it in a container of e85. Monitor for any changes etc.
  • Like 1
Pulsar Speedo almost hit 240 at PI with 235kw. Sort of expected faster with bikes or do they really need more power or better gearing for 200+?
I do the same with 300kw Lee. You must be flying out of that last turn.
I'm at 2.00 flat now, still trying to crack the 1.50's. What was your last time?
What times were you doing leeroy?
Think you asked me when I first started my build thread... Was first track day and cooked clutch 2nd session. Think around 2:15-25 with a lot of lost time on the hairpin trying to shift down gears lol
Took me a while to figure out why the clutch went so quickly. Previous owner had some happy times before handing the car over. I wondered why the almost unused RSR's were a lot rougher on the outside than when I first inspected it....
Gtrjet... FWD bro. Foot the floor just after you start the last corner
  • Like 1
Fellas, it looks like nice weather tomorrow. Anyone want to go get ice-cream and sit by the beach during sunset?
byo sunscreen though.
I'm down for something tonight but weather is Shit. I have some of those twix ice cream things in the freezer... $3 from iga. Would buy again
The rest is a wank. Uncomplicated science that people - usually those who aren't running the stuff - make into a big ol' Poirot murder mystery.
f**kING SOOOOOOOOO MUCH THIS
Can't expect them to match the pulsar brah
lol
No
This
Is it, Alvin?
Big fuel were behind the rumors initially. It also didn't help that ANDRA (who 100% coincidentally are sponsored by race fuel companies) banned the stuff
To be fair it probably runs
Kill yourself.
with fire
Think its time for a Harness to keep my sweet booty in one place. My weight alone isn't cutting it anymore.
10806287_1387896224845873_76438128422366
Also, boooo... Mods gon mod :(
https://www.dropbox.com/s/0c0rg17djegh6ov/Screenshot%202015-01-09%2009.22.39.png?dl=0
Is it, Alvin?
the metal lines will be fine, its the rubber that may or may not swell up, its a litigation issue. most will be fine, but fuel lines are not expensive. so just change them?
Edited by xALmoN
Fuel lines in the engine bay are easy to change, fuel line in the tank (from pump to lid) is easy to change... Its the ones that go from the top of the tank to the hardlines on the body that are annoying. Partially accessible from the drivers rear wheel well however.
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
