"hi, i have a bench top meat slicer i want to sell"
how old and what make?
"dunno"
can you send us some pictures of it?
"nah my phone doesnt have any credit, i can bring it past"
no thanks.
Toby if I'm renting out a room to a mate, should I just get cash off him for tax purposes or is direct deposit into my account okay? does it make any difference come tax time?
Birds - when you get the GTR brah?
Edited by UNR33L
whats the price of 91 atm?
when I left it was 1:13 so I would expect E85 to be sub 1$ by now...When ti was first out it was advertises at 25c less than 91..what happened?
julia guilard/tony abbott
I has it
Same thing that happened with LPG I imagine. More people use, more demand = can afford to push up the price. They would have made it cheap as shit to get people using it and now they have a decent customer base, someone has to pay for all the new pumps.
But 98 used to be 10 cents a litre more than 91, and the difference keeps going up. So as long as E85 stays lower than 98, proportionate to the extra fuel usage, I'm happy. Even if a little more expensive to run it's worth it.
United recently took over a servo 2km down the road from my house and put an E85 pump in - so handy! Used to have to fill up 3km away from my work.
Filled up the excel the other day, think 91 was like 1.09 at safeway petrol... Seems to have dropped a fair bit since I went to Thailand, then again I don't really look at the price when filling up so maybe I just didn't notice it
lpg is not the best example, it has stayed similar 50-60 c jsut when fuel prices when up it became less economical. and now prices dropping it's dropping at same rate.
expected the same for E85.
considering how much more you go though bet there not many of those flex fuel commodores using it atm.
EDIT:
just went and checked Holden site, seems for VF they dropped E85 support, so guess that answers that one,.
EDIT:
I disagree on the LPG, it may be proportional but back a few years ago during the LPG boom when every man and his dog were doing conversions for $500, the price of the stuff jumped up with little to no change to petrol prices. I was filling up at 40 cents a litre or less and out of nowhere the shit skyrocketed...I put it down to demand.
demand will always bump prices agreed.
not sure the demand is there for E85 tho, not a huge amount of cars running it.
other than the FE commo, who supports it from factory?
also with prices going up makes you wonder how long it sitting in tanks for.
Don't get me wrong, I'm not against E85, when I get around to changing injectors will be moving to it.
just thought it was cheaper is all.
Must be the aftermarket using it - that or united are seriously committed to marketing it, because they keep popping up new servos with E85 / installing tanks.
Alvin may like to correct me, but I don't think e85 goes off / loses it's octane in tanks as fast as say 98 would.
They would be sealed to prevent water build up, and alcohol/ethanol doesn't really go off over time?
(in some cases improves!)
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
