"hi, i have a bench top meat slicer i want to sell"
how old and what make?
"dunno"
can you send us some pictures of it?
"nah my phone doesnt have any credit, i can bring it past"
no thanks.
Toby if I'm renting out a room to a mate, should I just get cash off him for tax purposes or is direct deposit into my account okay? does it make any difference come tax time?
Birds - when you get the GTR brah?
Edited by UNR33L
whats the price of 91 atm?
when I left it was 1:13 so I would expect E85 to be sub 1$ by now...When ti was first out it was advertises at 25c less than 91..what happened?
julia guilard/tony abbott
I has it
Same thing that happened with LPG I imagine. More people use, more demand = can afford to push up the price. They would have made it cheap as shit to get people using it and now they have a decent customer base, someone has to pay for all the new pumps.
But 98 used to be 10 cents a litre more than 91, and the difference keeps going up. So as long as E85 stays lower than 98, proportionate to the extra fuel usage, I'm happy. Even if a little more expensive to run it's worth it.
United recently took over a servo 2km down the road from my house and put an E85 pump in - so handy! Used to have to fill up 3km away from my work.
Filled up the excel the other day, think 91 was like 1.09 at safeway petrol... Seems to have dropped a fair bit since I went to Thailand, then again I don't really look at the price when filling up so maybe I just didn't notice it
lpg is not the best example, it has stayed similar 50-60 c jsut when fuel prices when up it became less economical. and now prices dropping it's dropping at same rate.
expected the same for E85.
considering how much more you go though bet there not many of those flex fuel commodores using it atm.
EDIT:
just went and checked Holden site, seems for VF they dropped E85 support, so guess that answers that one,.
EDIT:
I disagree on the LPG, it may be proportional but back a few years ago during the LPG boom when every man and his dog were doing conversions for $500, the price of the stuff jumped up with little to no change to petrol prices. I was filling up at 40 cents a litre or less and out of nowhere the shit skyrocketed...I put it down to demand.
demand will always bump prices agreed.
not sure the demand is there for E85 tho, not a huge amount of cars running it.
other than the FE commo, who supports it from factory?
also with prices going up makes you wonder how long it sitting in tanks for.
Don't get me wrong, I'm not against E85, when I get around to changing injectors will be moving to it.
just thought it was cheaper is all.
Must be the aftermarket using it - that or united are seriously committed to marketing it, because they keep popping up new servos with E85 / installing tanks.
Alvin may like to correct me, but I don't think e85 goes off / loses it's octane in tanks as fast as say 98 would.
They would be sealed to prevent water build up, and alcohol/ethanol doesn't really go off over time?
(in some cases improves!)
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
    • Potentially some interesting data for some of you here; Hank Iroz from Iroz Motorsport testing a new Xona Rotor 5964S on a Audi RS3 2.5L DAZA motor. https://facebook.com/share/p/14EU18MyDqZ/ Cliff Notes: Turbo has the new Xona XRE compressor aero with an X4C compressor cover, reportedly 0.64 rear housing. 900whp (670kw) @ 37psi, 170k shaft speed, motor is making 2bar (29psi) boost by roughly 3800rpm, 500lbft (670nm) torque by 3500rpm. They overlaid a stock RS3 on USA 91 fuel (red), and a "Stage 2" RS3 on E85 (yellow), and this 5964S (blue) - the 5964S isn't losing any ground to either. Apparently out-flowing their prior tests with a Xona 8264S (green), and this 5964S (white) also has a smaller A/R than that did.
