Tightarse option.
Used 32 crank 120-150
Ebay Wide oil pump drive collar $90
Collar fitment/grub screw clean/crack test ~$300 total.
Spensive option.
New R34 crank, ~$800 overnight parts from Japan
Tightarse option.
Spensive option.
but if you overnight parts from Japan it will decimate all
how did that go?
pump replaced and all good?
All good!! Replaced sump baffle with trap doors and put some -7s on. Made 285kw on it's first run, stock ECU on 15psi. Cannot complain one bit!
Will be getting it flex fuel tuned before PI and hopefully do I dunno... maybe 320kw on E85 with stock injectors? Don't know yet!
Yeah but in all seriousness doe, 1.50s is very very quick for a non serious racer isn't it? I'm not super up to date on what is fast and what isn't at Phillip Island.
Might install an oil cooler next week to ensure I can even last an entire lap without getting too hot!
i did 1:57 first time out, street tyres 180ish RWKW
RSR all round
maybe 3 track days that year as the engine let go and got rebuilt
mid 50ish is what I call good for a 200ish RWD
53 or better with the bit of extra grip should be about right
richo and madden now into mid 40's but your not getting close to that.
Imma take it easy and hang around the 2:10 range lol
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
